What is this 2001 Heritage worth?
"I went to start the bike and let it run for a bit, but didn't disconnect the trickler and so i blew a fuse. (Turn switch to accessories and lights come on. Turn switch to on and the fuel injection doesn't make it's noise and the odometer stays dark."
Do y'all think it's just a fuse or could the FI system be damaged now?
I know this is a week ago.... but I'm hoping you ran away from this bike...!!!
Trying to starting a bike with the charger attached won't usually blow a fuse.... Unless it's a real old, crappy charger, or there is another problem with the bike....
A bike with high mileage and good maintenance is not a big issue....
A bike with high mileage, no maintenance history, and a problem that that the seller passes off as a "fuse" when it most likely is not... is a big problem...
If I was selling a bike and it blew a fuse due to my mistake, I would just replace the fuse, check that I fixed it, and move on.... The seller isn't telling you something... or knows very little about his bike...
I hope you let this one go and are continuing your search for a better bike... they are out there ....
