S&S E Carb Jetting
Old Jun 4, 2020 | 08:34 PM
npsocal's Avatar
npsocal
Default S&S E Carb Jetting
2001 Softail Standard
S&S E Carb
2 into 1 Exhaust
I’m having trouble nailing down correct jetting. When I role on the throttle there is a delay and then kind of spits or misses a beat?
current jets are
main 295
intermediate 72
Old Jun 4, 2020 | 09:49 PM
pococj's Avatar
pococj
Have you given S&S a shout? And checked for intake leaks? I put a S&S E on my '87 Softail ('99 crate motor) running old-style 2-into-1 style headpipes with a 30" fishtail straight pipe and it was set up perfectly from the factory.
Old Jun 4, 2020 | 10:08 PM
TwiZted Biker's Avatar
TwiZted Biker
Got the jets backwards , mains 72 and the im. is .295.
Far as jetting goes depends on the motor setup and condition, intake leak will drive you nuts chasing jetting and sounds like you have one somewhere.
Old Jun 5, 2020 | 12:28 AM
npsocal's Avatar
npsocal
I put brand new exhaust gaskets and flanges, checked for seal and it good. Only issue is when I throttle up hard it lags, slow role on is good.
Old Jun 5, 2020 | 08:00 AM
misfitJason's Avatar
misfitJason
Sounds like you need to adjust your accelerator pump
Old Jun 5, 2020 | 08:42 AM
npsocal's Avatar
npsocal
Zeroed everything out and starting over
Old Jun 13, 2020 | 06:59 AM
npsocal's Avatar
npsocal
In case anyone else has jetting questions I contacted S&S and they were great. Got me dialed in!
S&S E Carb
2 into 1 Exhaust
se 203 cams
intermediate jet is 31
main jet is 72
Old Jun 13, 2020 | 11:35 AM
misfitJason
All of the info that you posted above would have been helpful to know in your original post. Especially the cam info. That makes a difference. You have to help us help you and we are not mindreaders. Glad you got it sorted out
kansasroadking
Exhaust System Topics
Jan 20, 2024 09:42 PM
lonerider1960
Apr 1, 2020 11:06 AM
89FLHTC
Carburetor Related
May 6, 2016 11:40 AM
br549A1
Sep 11, 2014 09:33 AM
dert
Feb 3, 2006 10:26 AM
