Bike troubles
Old Jun 18, 2020 | 09:45 PM
Fatboy98 Special's Avatar
Fatboy98 Special
Stage IV
Default Bike troubles
I have a 98 fatboy with an S&S motor in it. Just rebuilt the carb but now the bike will not stay running longer than a few seconds. If I hold a rag over the intake it will run a bit longer. Any thoughts?
Old Jun 18, 2020 | 10:13 PM
Riffraff123's Avatar
Riffraff123
Welcome to the forum. Was it idling ok or not before you rebuilt carb? Cause it's very easy to put the needle jet backwards or set float height wrong, and other problems. Check HERE for some real good info on carbs.
Might want to introduce yourself in the new member area too...check the stickys in there.
Old Jun 20, 2020 | 06:49 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You forgot to tell us what type carburetor you are working on...
Old Jun 20, 2020 | 08:47 AM
Fatboy98 Special
Stage IV
It is a super E carb
Old Jun 21, 2020 | 05:12 AM
billbrummett's Avatar
billbrummett
Default carb
with the rag letting it run longer, u screwed something up in the carb. take down and redo..............
Old Jun 21, 2020 | 03:01 PM
Dan89FLSTC's Avatar
Dan89FLSTC
What would that screw up inside the carb?
Old Jun 21, 2020 | 03:30 PM
oldtoad's Avatar
oldtoad
I think he means that since it only runs longer with the rag in place he probably screwed something up when he reassembled it.
Old Jun 21, 2020 | 06:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I`m thinking a little slower than normal today, thanks
Old Jun 22, 2020 | 07:38 AM
1999 flstf's Avatar
1999 flstf
are you trying to run it with out an air filter?
Old Jun 22, 2020 | 03:27 PM
60Gunner's Avatar
60Gunner
Well it should run without one.
Did you change the float needle? Is it adjusted properly? Sounds like it runs out of fuel right away. Or you have the idle set way too low.
