Oil fat boy
Old Jun 20, 2020 | 06:06 PM
Gianluca's Avatar
Gianluca
6th Gear
Default Oil fat boy
good morning, I have the gearbox (63,000 miles) of my noisy 6-speed softail, what oil do you suggest? and for the primary one the original one is the same as water.
thank!!
Old Jun 22, 2020 | 12:03 PM
ChromeJunkie's Avatar
ChromeJunkie
I use formula plus in both holes on my bikes.
Old Jun 22, 2020 | 02:11 PM
misfitJason's Avatar
misfitJason
Spector gear oil. Formula plus is fine for the primary, however it is not gear oil
Old Jun 22, 2020 | 04:08 PM
60Gunner's Avatar
60Gunner
What's best for one isn't for the other. The Spectro Heavy Duty Primary Chaincase Oil is slightly thinner than F+. I prefer to thin it down more with B&M TrickShift conventional for better hookup that you may or may not like.
For the tranny...
https://spectro-oils.com/heavy-duty-...nsmission-oil/
For the primary...
24 oz. of https://spectro-oils.com/heavy-duty-primary-chaincase-oil/
8 oz of https://www.holley.com/products/drivetrain/trick_shift_trans_fluid/parts/80259
Old Jun 22, 2020 | 04:18 PM
Jackie Paper's Avatar
Jackie Paper
Formula + in both primary and gearbox. It is a straight 50 weight gear oil with no detergents or EP additivies. From a engineering standpoint, you do not want detergent in a non filter box. No EP for a wet clutch.
Your gearbox has a inner input shaft running inside the output shaft. It has a double row of small needle bearings .
Do not fall for thicker is better or try to quitten the primary or transmission. It's the nature of the beast.
Old Jun 22, 2020 | 04:35 PM
ahern25's Avatar
ahern25
I use redline or formula + for primary.
redline shock proof for transmission.
Comb
Aug 24, 2019 05:02 PM
Pierre
Feb 22, 2018 05:04 AM
Lilman
Jul 10, 2017 02:11 PM
_Gir_
Nov 19, 2013 09:30 PM
Bill G
Oil Archive (no new posts)
Jul 19, 2012 07:55 PM
