I searched through some old post but was wondering if someone can clarify this
Rocker tails have 4 wires...the aftermarkets i can find have 3 wires....how i can i wire them up so they work properly....also what parts or controllers do i need to buy....any detailed info is greatly appreciated...thank you.
The Rocker lights are also 6V and there are no aftermarket replacements available...A run/brake/turn signal module with a load equalizer will allow you to use 12V LED lights, and have them operate as run/brake/turn. Badlands has one specifically for the Rocker that's plug and play!
The Rocker lights are also 6V and there are no aftermarket replacements available...A run/brake/turn signal module with a load equalizer will allow you to use 12V LED lights, and have them operate as run/brake/turn. Badlands has one specifically for the Rocker that's plug and play! https://www.amazon.com/Badlands-Prod.../dp/B001P4K8QQ
Works great!
thats the one i was looking at...will this work with any 3 wire lights?
I just remembered my Thunderbike fender running/turn lights are 2 wire (center brake light is 3 wire)...so the Badlands unit works fine with those as well, and they also operate as run/brake/turn.
