Crossover fuel line
Old Jul 3, 2020 | 08:35 AM
WKNDS's Avatar
WKNDS
Originally Posted by DrPlastic
Where do we get one?
Search using the part number listed above.....
Here's one option;
https://www.jpcycles.com/product/721-853/efi-fuel-line
hth,
T.
Old Jul 3, 2020 | 08:41 AM
RockerE's Avatar
RockerE
Originally Posted by niv
Can you share a picture of your setup with the quick connect?
Thanks already, niv
I have a similar setup. I also love the look of the magnum crossover line as it would match my cables but after pulling the tank a couple of times much prefer the functionality of a quick connect. I have thought about getting two of those crossover lines and putting a quick connect in the center to keep the functionality while getting the looks. I think it might be a little too long though so I might just reach out to magnum to see if they will make me a crossover with my disconnect in the center. Conveniently they are located right here in my town.
Here is a pick of my current setup. I just put a little Taylor cable ShoTuff chrome loom on the lines as a temporary solution.
Old Jul 3, 2020 | 08:59 AM
showin4fun's Avatar
showin4fun
The part number was for a Harley Davidson Fuel Line. here is a link to a cheaper alternative:
https://www.ebay.com/itm/Twin-Power-...wAAOSw1Fhe6uBV
Old Jul 3, 2020 | 09:52 AM
niv's Avatar
niv
Looks similar to what I am planning:
I like the fact they seem to close automatically once disconnected, so noone could ever drain your tank just like that.
I found those here
https://products.cpcworldwide.com/en...e/LCNSF1/73800
and here
https://products.cpcworldwide.com/en...l/LC4/LCD17005
Anyone know where those could be bought from non-medical supplies? The above link doesn't show prices, but I am sure they are pricey...
Best regards, niv
Old Jul 3, 2020 | 06:53 PM
showin4fun's Avatar
showin4fun
I found those here
and here
Best regards, niv
Seems like you are going to have a lot going on with a such a short fuel line. I would rather have the cleaner look of a simple stainless braided fuel line like shown by the original poster.
Old Jul 3, 2020 | 08:03 PM
niv's Avatar
niv
That thought had crossed my mind too. But in RockerE's picture it looks ok and not too cramped. It's not that I take my tank off every other week. I am torn between this setup and just getting a fuel line to drain the tank (as per above) and some Oetiker clamps for spare or the braided X-over line. But it is appealing not having to drain the tank...
Another question: The braided line as per the original post, how does it connect to the "nipplies" of the fuel tank? I assume you don't just slide it over...
Best, niv
Old Jul 3, 2020 | 08:11 PM
showin4fun's Avatar
showin4fun
Best, niv
The only other thing about putting the disconnect in is that you have to lengthen the fuel line out quite a bit so you have enough room to take it apart. Look at RockerE's picture and notice how much longer the line is.
The braided line in the original post just slides over the barbs and when tightened it bulges the rubber ring to seal against the barb.
Old Jul 3, 2020 | 11:54 PM
gleam's Avatar
gleam
...Here is a pick of my current setup. I just put a little Taylor cable ShoTuff chrome loom on the lines as a temporary solution.
Looks good, thanks for letting me know about that cable wrap product, I hadn't seen that before.
Old Jul 3, 2020 | 11:59 PM
Clammy's Avatar
Clammy
I found those here
and here
Best regards, niv
I am running a similar setup on Reaper. These are the couplers I bought. 50 bucks total for the pair.
http://quickcouplings.net/osc/product_info.php?products_id=716 (LCD17005V - 5/16 HoseBarb Valved InLine CouplingBody w/Viton seal)
http://quickcouplings.net/osc/product_info.php?products_id=717 (LCD22005V - 5/16 HoseBarb Valved InLine Coupling Insert w/Viton Seal)
There's no room for the hose with quick connector between the bottom of the gas tank and top of the front rocker cover, so I ran the hose in front of the frame at the front, and covered it with plastic wire look heat shield tubing. It looks pretty slick if I do say so myself, and the functionality is so worth it.
I never took specific pics of the setup, but you can see it from the side in this picture. I'll grab a few shots tomorrow during the day, and update the post/thread.
Cheers!
Old Jul 4, 2020 | 01:43 PM
Clammy's Avatar
Clammy
Photos as promised:
Cheers!
