Not the usual blinker relocation question
Old Sep 8, 2020 | 09:49 AM
Dynalmadman's Avatar
Dynalmadman
Default Not the usual blinker relocation question
2006 Fatboy, factory handlebars and turn signals. I want to relocate the turn signals to the forks, and I think I have the necessary hardware.
I know the signals run to a plug on the right side of the tank. I plan on pushing the pins out and leaving the wiring complete.
My question: once I break open the switch housings and disconnect the turn signals from the housings, do you guys think it is possible to pull out only the turn signal wiring thru the handle bars, and leave the other wires in place? I will be putting apes on it later when it gets cold, but I'd like to get the turn signals done now and out of the way, literally.
Thanks
Michael
Old Sep 8, 2020 | 10:07 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Whoa....
You need to look at the wiring diagram...
The wires that power the signals have not come from the handlebar switches since the `95 model year...
The signal lamps are powered by the TSM/TSSM.
Old Sep 8, 2020 | 10:17 AM
Dynalmadman
You need to look at a wiring diagram...
It appears to me that the wires from the turn signals are routed thru the switch housings.
Old Sep 8, 2020 | 10:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Ok, I see what you mean...I didn`t think about the signals being so close to the housings so obviously they are routed through...
The wires that you need to move do not go to the switches themselves, they go down the the TSSM.
It looks like you can just de pin the wires down at the connector as you said. You won`t be messing with the wires that go to the turn signal switches.
Connector 31B, 2 Black wires, 2 Blue wires, one Violet wire, one Brown wire.
Hope I didn`t screw you up...
Old Sep 10, 2020 | 06:29 PM
Valdemar's Avatar
Valdemar
turn signals are routed thru the switch housings because all wires are inside the handlebar. But the turn signal cables are not joined to the swtichs, are individually to the connector under the tank.
scoledawg03
Jan 10, 2016 11:11 PM
blacklabel213
Oct 20, 2015 11:14 PM
Rogue8Man
Electrical/Lighting/Alarm
Aug 16, 2015 03:45 PM
ws6lvr
Mar 22, 2013 03:04 PM
stell55chevy
Sep 10, 2007 09:14 PM
