Softer Seat Springs
Old Sep 22, 2020 | 08:37 PM
Carl Childers's Avatar
Carl Childers
Default Softer Seat Springs
I'm looking for softer seat springs for a Crossbones sprung seat I want the same length just not as stiff. Sources?
Old Sep 23, 2020 | 08:57 AM
bustergut's Avatar
bustergut
Old Sep 23, 2020 | 09:16 AM
NoRegerts's Avatar
NoRegerts
Are you wanting something softer than the stock seat, or are you running the tractor seat? Depending on what you're wanting, Wild *** is a great option to consider as well. No mods needed and it worked incredibly well for me.
Old Sep 23, 2020 | 09:33 AM
Carl Childers
I used a Crossbones mounting kit on my Softail Slim and have a Corbin reproduction tractor seat mounted to that. On an earlier Harley I owned I had pretty much the same set up but the springs came from J&P Cycles. Those springs had just a little give to them and were perfect for my 195 lb weight. My current springs have 0 give to them and might as well be steel struts. Part of what makes these seats work so well is the built in suspension. J&P cycles is not what it used to be when I bought the last set up, back then they had numerous springs to choose from and you could best pick the tension that worked for you. If I had to guess the springs I have now are probably for a 250 lb rider. I'm hoping to find some one who carries springs that can give me technical data on them.
Old Sep 23, 2020 | 11:30 AM
Dynalmadman's Avatar
Dynalmadman
Maybe here?
https://www.lowbrowcustoms.com/colle...e-seat-springs
Old Sep 23, 2020 | 04:14 PM
MilsurpShooter's Avatar
MilsurpShooter
My home PC I think I have an old link to some springs which were recommended ages ago. They were a sort of "progressive" spring, lot of give at first but then stiffened up. I had contemplated putting them on my seat for awhile. Will update if I find it.
Old Sep 23, 2020 | 04:28 PM
WKNDS's Avatar
WKNDS
This is a bit pricey in my opinion, but you might check out the airspring from TCBros...
http://www.tcbroschoppers.com/air-ri...at-braket.html
good luck,
T.
Old Sep 23, 2020 | 07:08 PM
Carl Childers
Madman, thanks!
Shooter, I think a progressive spring would be ideal. I hope you can find that info.
WKNDS, Thanks, I like that air spring but I want to stay with a more traditional look.
Old Sep 24, 2020 | 02:08 PM
MilsurpShooter
Sorry Carl, no joy on the link. Brings me to a 404 page, no longer found. But it was off the Lowbrow Customs web page. Sorry I couldn't help more
Old Sep 24, 2020 | 04:29 PM
Carl Childers
Your effort is much appreciated.
1Reaper
Nov 11, 2019 12:47 AM
FLMARK
Aug 5, 2014 02:49 PM
CanuckBones
Apr 3, 2013 10:26 AM
christer_malmesjo@hotmail.com
May 2, 2012 11:53 AM
baron3547
Apr 2, 2007 02:52 AM
