Brake light stays on
Old Oct 2, 2020 | 08:02 PM
P8ence's Avatar
P8ence
Default Brake light stays on
Have replaced my bars on my fatboy 2010 now the brake light stays on.
follow me.
press the lever brake light dims
Let the lever go brake light goes on
Removed the orange/white wire from the connector brake light dims (press the foot brake light illuminates
Swapped the wires in the connector, re-installed and brake light is solid
so the both switches are working front and back. Whyis it working opposite? Press goes off, let go and stays on?
cheers
Old Oct 2, 2020 | 08:56 PM
YZR's Avatar
YZR
I had the same problem. There is a small, bent brass piece that goes over the pointed tongue on the brake lever. This piece holds the switch in when the lever is not in use.
Mine got lost when I was messing with the throttle assembly and I took a half inch long piece of 1/4" ID tubing, cut a slit in the middle and stuck it on the tongue. It worked like a champ!
For my 2008 Heritage it was part no. 71587-04 but I am still running with my homemade fix.
Old Oct 3, 2020 | 03:25 AM
P8ence's Avatar
P8ence
Nah wasn’t that but thanks. thought it was wiring so i’ll remove all the wires from the connector. I put back only the wires for the switch into the connector. Still the same. I thought then why are the switch wire black and Black/red? Old switch orange and red? Connected the old switch in and wala!!! Works. Looked at my order and my order was correct but the shop sent me a clutch switch instead. There you go, will be on the phone on Monday lol
Old Oct 3, 2020 | 08:16 AM
DrPlastic's Avatar
DrPlastic
Did you run the wire internally, in the bars??
Old Oct 3, 2020 | 10:23 PM
P8ence's Avatar
P8ence
yep but nothin to do with the wires, its the switch. Ppl think the clutch and brake switches are the same. Not. They have opposite components to the way they work. Cheers
Old Oct 4, 2020 | 09:30 AM
Elusive1972's Avatar
Elusive1972
follow me.
cheers
I have a similar problem on my 2017 Softail Slim FLS . I press the brake lever and the brake light stays on unless i push it back with my fingers..Seems like the master cylinder piston won't retract because of all the gunk built up inside of it throughout the years..My bike has 32k on it so I am going to clean the switch before replacing the master cylinder..Harley dealership immediately wants to replace it but I don't trust them..
04stangman
Mar 4, 2013 01:38 PM
woodster54
Sep 24, 2012 08:50 PM
code.mafia
Aug 7, 2009 11:51 AM
moblmowr
Feb 29, 2008 08:00 PM
ian
Feb 6, 2007 07:16 PM
