Lift Point
Old Nov 7, 2020 | 12:53 PM
Carl Childers's Avatar
Carl Childers
Default Lift Point
I have my 2013 Slim up on the lift table with the front wheel clamped in the vice, I want to just lift the rear wheel up so what I'm wondering is it alright to place my small lift jack underneath the shock absorbers? Are they up to the weight and stress load or should I place the jack as far back on the frame as I can without it touching the shocks?
Old Nov 7, 2020 | 03:36 PM
m1369x's Avatar
m1369x
1/4in plate wider than frame on your jack (presume you're useing a scissor jack) or a 1x4 (might flex) , some times I'll slip a square of lath on each side
Old Nov 7, 2020 | 04:17 PM
470004's Avatar
470004
https://www.harley-davidson.com/us/e...ors/p/94675-99
Old Nov 7, 2020 | 06:35 PM
cocky's Avatar
cocky
I just use 2- 6" pieces of auto heater hose slitted length wise to go around each frame rail. Jack will contact the rubber hose and not the frame.
Old Nov 7, 2020 | 09:19 PM
hattitude's Avatar
hattitude
I use the frame protectors. While designed to protect the frame rail, they are thick enough to keep the jack from pushing on the shocks because they hang just a touch lower than the frame rails... However, I lifted my 2003 softail for years on a Sears jack and then J&S jack, without noticing that one of the bars was pushing on the shocks... I didn't damage anything, but I decided not to take the chance anymore....
There are other "remedies" as mentioned, but basically anything that will cause the jack to push on the frame instead of the shocks... depending on the width of your scissor jack, you may be able to raise it by having it contact the frame just aft the shock bodies...
In this pic you can see the frame protector (yellow arrow) keeping my scissor jack from pushing up on the shocks...
Old Nov 7, 2020 | 10:41 PM
S.D.M.F's Avatar
S.D.M.F
splashback
Aug 27, 2018 10:48 PM
Big Dave
Nov 5, 2017 05:57 PM
keith t
Nov 1, 2013 05:17 AM
Motown Strag
Jan 13, 2013 02:56 PM
kzman
Mar 16, 2006 11:10 PM
