New fuel pump sputtering on acceleration
Old Apr 15, 2021 | 10:12 AM
hattitude's Avatar
hattitude
Originally Posted by DrumHog65
I don't have immediate access to a fuel pressure gauge, So I pulled the fuel pump assembly out again, just to make sure everything was seated correctly. It seems the regulator housing was slightly separated from the fuel filter. I gave everything a nudge and a squeeze and confirmed everything was clicked in place. I buttoned everything up and took her for a test ride. It is now running much better, almost like it was before I replaced the fuel pump assembly. I now have a little bit of a flat spot on acceleration with the occasional sneeze out the AC. When I bought the bike new, I had the 95 cu in kit as well as the Stage 1 option installed. Should I need a remap of the ECM after replacing the fuel pump?
Thanks in advance for any advice.
Cool, glad to see you found the issue...
Changing the fuel pump does not require a change to the tune... any sudden change in drivability issues, should be from other sources... make sure maintenance/wear items are up to date/spec....
FWIW... I had the dealer install an HD 95" big bore kit back in October 2003, in my 6 month old 2003 Heritage. It had the SE203 cams and was tuned with the standard HD Big Bore download tune of that time period. The bike ran well for many years. Several years later I added a downloaded tune from DynoJet, via my PowerVision... it really woke that bike up.... Certainly wouldn't hurt to get it tuned, but a tune shouldn't be needed because of an oil pump change....
Old Apr 15, 2021 | 10:32 AM
DrumHog65's Avatar
DrumHog65
6th Gear
Thumbs up
Thanks hattitude! Time to start checking off all the boxes making sure things are to spec. Even if unrelated, perhaps a tune is on the horizon.
shoveleighty
18
Oct 9, 2020 11:00 AM
fourburgs
Milwaukee Eight (M8)
Jan 7, 2020 06:37 PM
cdorsey50stang
11
May 5, 2017 12:15 AM
Howard Richman
Engine Mechanical Topics
Mar 2, 2014 06:28 PM
hdheritage04
Exhaust System Topics
Nov 14, 2007 07:28 AM
