07 Night Train won't start!
Old Aug 3, 2007 | 06:08 AM
ybn533's Avatar
ybn533
Default 07 Night Train won't start!
Hi,
Need your help to find out why the bike won't start.
I checked the battery and it's ok. when I turn the switch, the Light and all the instrument work only the starter doesn't work.
When I pull it on the street the bike starts!!!
The dealer change the swingarm to chrome, maby it did something wrong on the connections?!
It seemsthe problems is elictrical. or thethe wires from the batterytothe starter, fuse, minus ???
Does anyonehad this problem? the bike only have 1000 miles!!!
Thanks
Yaron from Israel
Old Aug 3, 2007 | 07:44 AM
BlueDragon's Avatar
BlueDragon
Default RE: 07 Night Train won't start!
I'd definitly start with the fuse~ If you can 'pull' start it then it's more then likey a dead battery... or a the starter switch is grounding out somewhere~ But then again, I'm just barely above a shade tree mechanic!
Good luck...
Old Aug 3, 2007 | 08:05 AM
skullandcircle's Avatar
skullandcircle
does it make a clicking sound when you try to start it? if so , it is probably the battery. Just had that happen to me. [/align]
Old Aug 3, 2007 | 08:09 AM
ybn533's Avatar
ybn533
I just fixed the problem!!!
The problem was at the starter relay. it was in it's place but when I touch it, the starter became alive
so I took it out and set the "legs" so it will fit inwithout any space\ movmentand sit strong.
Some little things came make you go insane....
chopped7
Apr 25, 2015 09:49 AM
flht2009
Apr 8, 2014 08:15 AM
epflynn
May 15, 2013 04:38 PM
dirtyboy
Ironhead
16
Jun 7, 2009 05:45 AM
petri48
May 17, 2009 10:18 PM
