07 Deluxe new owner question
Old Jul 12, 2021 | 08:04 PM
marksv4's Avatar
marksv4
Default 07 Deluxe new owner question
I have only been enjoying this Deluxe for a few days but have contacted the "boards" or mounts for the boards a few times while cornering, way more clearance on my Night Train. Is there any mod out there to correct how low this seems to be?
Old Jul 13, 2021 | 06:35 AM
slothtail's Avatar
slothtail
Is there a lowering kit installed? If so obviously you could go back to stock. I’m an auto tech now but i spent some time at a motorcycle shop as a tech. Most of the bikes with boards even road queens when ya put them up on the lifts, just about all of them had some scrapes on the boards and mounting components. Make sure tire pressure’s are to spec its amazing how much clearance you can lose with soft tires. Also, you could try adjusting the shocks a little stiffer that will take out some bounce that might cause an occasional bottom out. In fact, front fork springs can get weaker as the bike accrues miles. You could throw in some springs and use screamin chicken fork oil which is heavier than the E weight it comes stock with.
Old Jul 13, 2021 | 08:34 AM
marksv4's Avatar
marksv4
thanks i will make the necessary checks, also changing the front cartridges/springs to Progressive
Old Jul 13, 2021 | 10:11 AM
YZR's Avatar
YZR
They could also be pushed outboard with a relocation kit (I've done it to my 08 Heritage) which will reduce your lean angle also.
Old Jul 13, 2021 | 11:57 PM
byersmtrco's Avatar
byersmtrco
Deluxe comes stock lowered 1” in the rear.
Old Jul 14, 2021 | 12:04 AM
marksv4's Avatar
marksv4
Well how do i get that inch back? Im used to riding aggressive and cant keep scraping the board brackets
Old Jul 14, 2021 | 03:53 AM
Bone Doc's Avatar
Bone Doc
Assuming everything is stock, you may be riding more aggressive than the bike is meant to be ridden. If you like leaning in the curves then maybe the Deluxe isn't the right bike for you.
Old Jul 15, 2021 | 09:08 PM
badaim's Avatar
badaim
Add one turn of preload to the rear shocks if they are at the softest setting. That will gain a bit of clearance, but just barely. If you carry a passenger, go 3 turns. There are threads that give you the exact recommendations based on your weight.
As said above, Deluxes are 1 inch lower stance than most softails. You can change the shocks to either HD's at regular length or other aftermarket brands and gain that lost1 inch back and more lean angle. I scrape my boards on corners and round-abouts going at very sedate speeds too, so I will likely change the suspension on my (new to me this year) 2006 Deluxe.
Old Jul 15, 2021 | 11:11 PM
Flyin'Amber's Avatar
Flyin'Amber
My '13 has the longer rear shocks installed and the preload cranked up. I still drag the boards just turning normally. It's just how they are.
Old Jul 23, 2021 | 10:37 PM
hattitude's Avatar
hattitude
Even if you are at OEM shock adjustment, the 2007 Deluxe has less lean angle than the 2009 Night Train.... The Deluxe has 3° less lean angle on right turns and 8° less lean angle on left turns...
2009 Harley Night Train lean angle (per SAEJ1168): 31°/ 34°
2007 Deluxe lean angle (per SAEJ1168): 28° / 26°
You can maximize the preload on the shocks, but not sure how much that would help, and it will ride like a rock....
As someone said, the Deluxe is not designed as a canyon carving bike...
