Dropped her
Short of being a kick start
Good Luck WP
Then, check the battery, all battery/power cables, and especially the grounds for good connections..... and don't forget connections on the ignition switch, and eventually the ignition switch contacts themselves..
Unfortunately, if there is a weak electrical component (or connection), a firm, sudden jolt, can cause it to fail.... remember the old drop lights? Too many times I've had one fall to the ground and the jolt breaks the light bulb element...
It could be anything from a connection within the battery, to an external cable connection, to a relay, to a switch, to a ????? You might need to do some extensive testing with your multi-meter...
If the BAS, battery & cables check out OK, since it's not kicking over, I would probably start testing backwards from the starter, looking for 12V power...
Electrical "glitches" require persistence to track down....
Good luck and please report back what the fault was, when it's found and corrected..
hook up a jump box or battery charger that has a jump cycle on it ... to the cables on the bike
sometimes we do that with cars in work that have been hit , sometimes it resets the sensors and such
then use the box and see if it starts
worth a shot
