Dropped her
Old Jul 15, 2021 | 06:00 PM
Thumper#1's Avatar
Thumper#1
1st Gear
Default Dropped her
Dropped 2010 fxstc on right side.Wont start.On the dash I only have a weak oil light and a weak headlight.They drain down after a few seconds..She doesn't try to start at all.Please help
Old Jul 15, 2021 | 06:05 PM
tngarren's Avatar
tngarren
I'd start at the battery. Hope she was not damaged.
Old Jul 15, 2021 | 06:09 PM
Thumper#1's Avatar
Thumper#1
1st Gear
Default Dropped her
She's not hurt just my feelings
Old Jul 15, 2021 | 06:27 PM
Clammy's Avatar
Clammy
Likely tripped the Bank Angle Sensor. Try cycling the ignition switch on/off 3+ times, then try starting.
Cheers!
Old Jul 15, 2021 | 06:29 PM
LouTX's Avatar
LouTX
Sorry to hear. But no worries, it is likely fixable.
First of all, I'd check all connectors in the front, by the tank, check the cables and wires in case something got pulled.
Did the tank get hit & jostled. I'd check the connections on the tank controls and lights as well.
If you cannot find anything obvious, it might be time to break out the test light, diagrams and start checking wires, power, grounds etc. Electricity is not magic.
Old Jul 15, 2021 | 06:30 PM
LouTX's Avatar
LouTX
Cheers!
3 times? Didn't know. (I guess I should RTFM, right?)
Would a tripped BAS cause fading lights like OP described?
Old Jul 15, 2021 | 06:56 PM
Thumper#1's Avatar
Thumper#1
1st Gear
Default Dropped her
The fading lights really has me puzzled
Old Jul 15, 2021 | 07:05 PM
tngarren's Avatar
tngarren
You need not feel bad. I had not dropped a bike on the tarmac in 30 years, until a couple months ago. Was doing a slow U turn on a two lane, jerked my handlebar to shift the view of the left rearview mirror, me and Ducati fell over in the road.
Old Jul 16, 2021 | 10:07 AM
Clammy's Avatar
Clammy
Not that I know of, but my first attempt would be to reset the BAS. The fading lights sounds like a bad battery, but I can't see how a slow drop, would kill the battery... mind you, I never say "never". I've seen some weird stuff over the years.
Cheers!
Old Jul 16, 2021 | 10:11 AM
Thumper#1's Avatar
Thumper#1
1st Gear
Default Dropped her
I really don't know much about the newer bikes.If it was the shovel I probably could figure it out.Looks like she's off to the shop
