Brake lever too stiff after swapping levers
Old Sep 18, 2021 | 10:49 AM
jj14x's Avatar
jj14x
Default Brake lever too stiff after swapping levers
Edit: just realized I posted in the wrong sub - Mods, could you please delete this? I'll create new post in the right forum
Hi! This is the opposite of the usual problem, so unsure how to address.
2019 FXFBS - I wanted to swap my chrome levers out with the black ones - bought the HD ones (non-adjustable). Install was fairly simple - followed the video at
The clutch lever is great (actually feels a little bit easier to pull - which makes no sense) - I verified that the clip at the bottom is in the right position.
However, the brake lever is really tight - as in, almost no play. With the old lever, I could pull it about half an inch or so before it would start applying the brakes, and even then, it was relatively gradual/smooth. I could never pull the brake lever more than half way in (so, it was not spongy/soft) - it was just right. With the new lever, it has almost no play. So, squeezing the brakes is using the tips of my index/middle fingers - where as with the old lever, I got max brakes when the lever was close to my middle knuckle.
The brake lever doesn't really seem to have any adjustments that I could have screwed up (that I could see) - and I didn't open the brake reservoir at all.
Any suggestions on how to make it a little softer? (I could buy the adjustable ones as a last resort, but trying to avoid spending another $250-$300 for that)
Old Sep 22, 2021 | 05:44 AM
back again's Avatar
back again
Just a thought. Remove the powder coating from the contact areas of the lever. Most coaters do a good job of sealing holes and exposed surfaces that could have an interference fit. Powder coating is thicker than most people think. We are talking about Harley produced pieces here after all.
cartjack
Jul 2, 2019 08:20 AM
RoadAgents
Aug 22, 2010 09:53 PM
MuddBugg
Jan 22, 2010 07:47 PM
ron1019
Nov 20, 2007 01:55 PM
jopr175
May 24, 2006 11:36 PM
