Brake lever???
Old May 23, 2006 | 01:10 AM
jopr175's Avatar
jopr175
2nd Gear
Default Brake lever???
So today I noticed the front brake lever was stiffer than normal. Brakes working fine but there was no give in the lever. So I get back on my bike to go pu dinner tonight and there's alot of slack and play in the lever. Again, brakes worked fine but now the lever has alot of give to it.
Any ideas what this could be?
Old May 23, 2006 | 03:42 AM
jopr175's Avatar
jopr175
2nd Gear
Default RE: Brake lever???
[sm=helpout.gif]
Old May 23, 2006 | 08:07 AM
Thumper26's Avatar
Thumper26
I'm just guessing without being able to take a look, but are the adjuster nuts snugged up to the handgrip? If they are loose, the casings can get "caught" and cause a lever with no play; if they they are loose and not "caught", they can act with a lot of slack.
Thumper26
Old May 23, 2006 | 03:11 PM
alexcue's Avatar
alexcue
what model Sportie do you have? the R model with the dual brakes?
Old May 24, 2006 | 08:03 PM
jopr175's Avatar
jopr175
2nd Gear
ORIGINAL: alexcue
Yep, an '04 Roadster, dual front brakes . . .
Old May 24, 2006 | 09:14 PM
alexcue's Avatar
alexcue
Well you may have to rebuild the master cylinder, since a tech around here mentioned it's a known problem with the dual brakes. I've read more than a few people having this problem. If you're still under warranty take it in.
Old May 24, 2006 | 11:36 PM
jhugs92's Avatar
jhugs92
totally agree with alexcue. my 05 1200r is having the same problems. took it to dealer and they said that they will have to take master cylinder apart to find problem. i suspect a master cylinder rebuild will be in the near future for my bike. it is annoying though, one day it acts hosed up and they next day just fine.
cartjack
Jul 2, 2019 08:20 AM
rhuff
Mar 18, 2016 02:11 PM
smokeygold
Nov 20, 2012 11:37 AM
MuddBugg
Jan 22, 2010 07:47 PM
ron1019
Nov 20, 2007 01:55 PM
