CO-563 ABS Module High Voltage
Old Sep 30, 2021 | 02:18 PM
Mike Zdilar's Avatar
Mike Zdilar
4th Gear
Default CO-563 ABS Module High Voltage
I get a CO-563 ABS High Voltage code. My issue is the overdrive light in 6th gear will go out causing the red security light to come on. My turn signals both left and right will not work till the red security light comes back on and resets itself. I have cleaned the grounds on both the battery and the frame above the battery. This is a 2012 Harley Custom Deluxe. I have read another post of a code being PO563 high voltage and it was cured by cleaning the ground. Guess charging system scensed a low voltage situation and put the electrical system in a overcharging mode.
wallacc
Electrical/Lighting/Alarm
May 27, 2021 03:15 PM
Khanh Lee
Dec 12, 2019 07:09 AM
rsking45
Oct 2, 2016 06:56 AM
DieselDummy
May 26, 2015 05:02 AM
jrobinson424
Nov 22, 2012 12:38 PM
