2017 softail won't start
Old Oct 3, 2021 | 07:15 PM
Djaeperez's Avatar
Djaeperez
Stage II
Default 2017 softail won't start
I have a trouble code B2116 Fuel output open, ive changed out the check valve and line assembly in the tank (which was broken) and still nothing. Bike will turn over but wont seem to try and fire up. Though maybe it could be the fuel pump or possible clogged fuel injectors??
Old Oct 4, 2021 | 06:39 AM
greybeard122's Avatar
greybeard122
You have an electrical concern if you have that DTC. You possibly have an open between your fuel pump relay and the pcm. Clogged fuel injectors won,t give you an electrical DTC. Follow the steps to repair that code. Does the fuel pump prime when you hit the run button? If it doesn't, that's a problem.
Old Oct 4, 2021 | 01:46 PM
Djaeperez's Avatar
Djaeperez
Stage II
Yes the fuel pump kicks on when i turn the key over. I tried starter fluid and it cranks for a few seconds which is why i thought it was the injectors not sending fuel but ill look more into the electrical side of it.
Old Oct 5, 2021 | 06:28 AM
greybeard122
If it fires using the starting fluid, then its a fuel problem. If the crank sensor doesn't send asignal to the pcm, it won't activate the fuel pump to start. You can check it with an ohm meter.
demz
May 28, 2024 09:03 AM
Longshot USMC
Jul 24, 2014 10:25 PM
krzldy1949
Jun 28, 2014 04:58 PM
Whiskyjock
Jan 26, 2014 09:58 AM
sidewayz
May 26, 2005 01:27 PM
