sputtering problem
Old Aug 11, 2007 | 05:16 PM
camo660grizzly's Avatar
camo660grizzly
Stage I
Default sputtering problem
i got a 2006 softail with screaming eagle slip on exhaust and it pops and wines like it dose get enough gas when i floor it what would you guys suggest to help me out and what good websites are there?
Old Aug 11, 2007 | 08:52 PM
fxehillbilly's Avatar
fxehillbilly
Default RE: sputtering problem
whatoctane fuel u runnin? u have it re-mapped? I have an 06 fxst 95in. if i dont run 92 or higher it does the same thing
Old Aug 11, 2007 | 09:38 PM
mentor70's Avatar
mentor70
Dose it pop out of the air cleaner or the pipes, if its out the pipes, your "shooting ducks"!
if its popping out the air cleaner you may be running too lean!
Old Aug 11, 2007 | 09:44 PM
Chief101's Avatar
Chief101
First, did you change the a/c as well? Or just use the slipons. If you only went with slipons it should have been ok. Recheck your clamps and tighten to specs using a torque wrench........ar at least as tight as you can get them. did you loosen the pipes at the head? If so, check them agin as well.
If you changed your a/c with the pipes, you need at the very least a download, or even better, some tpye of fuel management system, such as PCIII, SERT, etc.
Finally........and its a silly question, but did you keep the baffles in the SE slipons or are they knocked out/ drilled?
rottiepete
Feb 27, 2015 10:11 AM
kmealp
Mar 23, 2009 11:02 PM
dhc8guru
Oct 1, 2007 05:41 PM
1954junk
Sep 28, 2006 01:57 PM
stbobber
Apr 18, 2006 07:06 PM
