Fork Fluid
I fill them, pump the dampers slowly to release all the air pockets, then check that the level is correct... I usually have to add just a tad more after pumping....
Another thing to note, fork oils get thinner, when they heat up. Most have a basic spec and then a 100°C spec. Harley Type E is 20W, but drops to 7.95W @ 100°C. If you are a hard rider, who frequently "works" his suspension hard, you may want to start with a heavier weight fork oil..
I believe most HD bikes come OEM with their Type E fork oil (20W).
If you want a more compliant (bouncy) front end you could go with HD Type B fork oil (10W)...
If you are a canyon carver and want a stiffer front end (Ha, I said stiffer front end) you could go with the Screamin' Eagle Type heavy fork oil. It is also 20W, but fades (gets thinner) less at high temp than Type E.
HD also used to make a very heavy SE fork end oil called extra heavy, which is like 60W... I would guess for racing only, probably unsuitable for street use...
I use Bel-Ray High Performance Fork oil... They make it in 5W, 7W, 10W, 15W, 20W, and 30W. So you can pick a weight and give it try, or there are numerous weights for mixing...
The beauty of fork oil is that it's not that hard to change, and if you pick a weight that doesn't suit you, it's not too hard to change it to something more/less compliant....
Good luck with your decision...
PS- Here's a chart by Spectro Oil on fork oils. It shows the "thinning" of the oil at temp..
This is a chart showing the min and max viscosity of a particular grade of fork oil at the test temp of 100c (212F) in centistokes.
It says that a SAE Grade 5 fork oil must have a viscosity between 3.80 and 4.09 centistokes at 100C to be labeled an SAE 5 fork oil.
Anything below 3.08 does not qualify for a 5 weight (too thin) and anything above 4.09 is a 10 weight.
This is why company A's 5 weight fork oil can offer a different feel in the the forks than company B's fork oil, one can be blended to the low end of the range and the other to the high end...they are both 5 weight but could react differently in your application
This is not a chart showing the thinning of fork oil at temperture
That's why I put the word thinning in quotations.... but I can see I was clumsy in my wording and use of that chart...
I was unaware that was the test for fork oils to qualify for their various weight ratings, I thought it was just a standard for comparison..... so thanks for the education on that point...
Thank you for clarifying...
Some of the chemical engineers I worked with had centi's in the brain.
"Centistokes is a decimal fraction of kinematic viscosity unit stokes. One centistoke is equal to 0.01 stokes"
It is not the min and max chart for "W" rated oils
OK.. now you guys are way over my head.... can't say I understand what that means...
Like I said, clumsy (inappropriate) use of that chart. I know now, that it doesn't show what I thought it did. I misunderstood it's meaning....
I shared it from a Spectro oil tech bulletin. Obviously misunderstood it, and shared it out of context from the bulletin (trying to be brief)
I THINK what I have learned here is that it shows the testing range needed, to receive a particular weight for a fork oil...
In any case, I'll just sit the rest of this discussion out in the back of the classroom shooting spit wads, and let the adults discuss fork oils...
That's something I have plenty of experience with......
Also, looks like the Bel Ray is on the high side of the 100 degree range for a given ‘viscosity’
http://www.belray.com/wp-content/upl...-23Nov2021.pdf
