Front turn signal wiring harness
Old Jun 16, 2022 | 10:16 PM
Ken_A's Avatar
Ken_A
Stage II
Default Front turn signal wiring harness
Looking for a part number for an oem or aftermarket Y harness for the front turn signals. Even a pig tail that plugs in and I can extend to the turn signals I want to use. 2004 night train is what I am working on.
Old Jun 18, 2022 | 06:57 PM
hattitude's Avatar
hattitude
OEM they look to be mounted on the fork at the bottom triple tree...
Where are you trying to move them to ...?
Most of the extensions I've seen are for Canbus bikes and used to extend the front turn signal wires, mounted on the switchpaks, for ape installs... Perhaps they could fit, I don't know...
You could call Namz, they make excellent wire extensions.. I've used them for my handlebar installs... Maybe they can help
https://namzcustomcycleproducts.com/...yourself-kits/
If you are a wire it yourself guy... the OEM turn signals look to plug into the harness on the right side of the backbone, just at the front of the tank, or maybe the frame neck... you could disconnect there and add wire from there....
Ken_A
Jun 17, 2022 05:18 AM
Tony Underhill
Electrical/Lighting/Alarm
Apr 20, 2017 07:07 AM
Shane70987
Mar 14, 2009 09:08 PM
michaelbarry
May 22, 2007 07:50 PM
hddawg
Apr 6, 2006 01:00 AM
