Hi guys I recently had my front fender repainted & when I re-installed it I can hear the tire rubbing on the right hand side of the fender, there are only 2 bolts each side holding it on, I had the bike on a lift & there was no rubbing at all but when I lean into a right hander at low speed going around my town I can hear it rubbing, I'm baffled to what's causing this, there is only about 5 to 10mill clearance each side of the tire, it never did this till I took the fender off, any help would be appreciated
That's a pretty simple fender arrangement... nothing to really mess up when reinstalling... but obviously something has changed between the removal of the fender and the reinstallation of the fender...
Does the clearance and fit look the same as before the fender was removed.....?
Did you just unmount and remount the fender, or was there some front end work done, tire and/or fork removal done at the same time....?
If nothing was touched except the fender, then I would have to suggest the fender itself somehow got tweaked during the removal, repainting, and reinstallation....
Hi, thanks for your reply & input, basically the fender was just removed & repainted, tires haven't been changed or anything else, I'll take it out to my friends shop & see what he says, I regard myself as above average with the spanners, so it annoys me somewhat that I cant see any issue--I'll get to the bottom of this by hook or by crook as they say, once again many thanks
I'll be sure to let you know ad soon as I rectify this I'm going to measure the clearance both sides with a micrometer & see how I go from there. Many thanks for your help
Hi 'Hattitude', I ended up removing the front wheel & fender in order to see if there were any indents or the lie on the inside of the fork legs that were locating points, but there were none, so I went out to see the guy who resprayed the fender, he maes Featherbed frames with bronze welding__ he had a good look at it & noticed that there was virtually no clearance on the bottom of the left hand side at the rear of the fender, he took it off & very gently pulled it apart at the bottom of the rear part, Ihad been hesitant to try this as I didnt want to crack the paint, but he ddid it so incrementally it was fine, & he could have fixed it as he had the paint etc, it still doesnt explain why it was rubbing in the first place, but at least it doesn't now.. many thanks for your input, I do appreciate it---------Geoff
Just glad it's all sorted, didn't like the fender rubbing when the bike was banked over to the right.I found it puzzling as it didn't do it previously 👍👍👍
