Will my vance and hines exhaust manifold flanges off my softail fatboy fit on to a set of softail slim standard pipes .i need to fit the slims pipes for roadworthy test .thanks for any help
Many aftermarket exhaust systems require you to swap the exhaust manifold clamp and retaining ring from your OEM exhaust to the new system... and of course a new exhaust gasket... I believe all the Vance & Hines exhausts I've used were like that..
I'll only add...... The retaining rings can get buggered up during the exchange. If the retaining ring gets bent or tweaked, it can affect your exhaust gasket seal...
