My 124" Build
Old Sep 13, 2022 | 12:59 PM
Berick's Avatar
Berick
Default My 124" Build - 2014 Fatboy Lo
I always like seeing these so thought I'd post mine. I recently purchased the S&S Hot Set Up and swapped out the 640 cams for 585's and the 11:1 pistons for the 10.2:1 pistons. I wanted a cooler running engine good for passing on the freeway and fun for burning around town or on the highway. The shop had a lot of problems with S&S parts. They were either on back order or there were quality control issues. The engine was torn apart a few times due to faulty parts from S&S. After about 18 months I finally have a bike that meets my expectations going into this whole ordeal (still a bit more tuning to do for hot idle and start up idle). I was aiming for 125hp/140tq. I know it's not a rocket compared to others I have seen on here but it should hopefully be reliable. If I didn't have a balanced engine I think my numbers would have been closer to where I had wanted them.
Build:
124" Hot Set Up (subbed cams & pistons)
S&S Superstock 91cc Heads
Stock bottom end with bored out cases and Timken Sleeve installed (I had a 103B engine)
585 Gear Driven Cams
Low Comp 10.2:1 Pistons
S&S Oil Pump/Cam Plate
Trask Clutch Basket
Factory Clutch with AIM Plate
Darkhorse Man-O-War Motorsprocket (34 tooth) with factory tensioner
HPI 58mm Throttle-body with HPI 6.2 Injectors
D&D Fat Cat 2-into-1 Exhaust
Screaming Eagle Heavy Breather AIr Intake
Celticson
Twin Cam Motors
52
Jan 2, 2022 06:34 PM
Iluvspdtt
Oct 26, 2021 10:27 AM
iMedic
Engine Mechanical Topics
56
Jul 29, 2021 05:56 AM
anubisss
Jun 15, 2011 07:25 AM
gaspare8
Jul 11, 2006 07:53 PM
