Tc 88 cam plate question??
Old Sep 21, 2022 | 02:46 PM
Charles F's Avatar
Charles F
Default Tc 88 cam plate question??
I am changing the tensioners.. the problem I'm having is when I pressed the cams out the bearing came with the cam can I go ahead and press these back in after I put the new tensioners on?? or do I have to replace the bearings now because I pressed it out?
Old Sep 21, 2022 | 03:18 PM
Rounders's Avatar
Rounders
They are not much money. I would replace them. All 4 bearding from s&s is under $70 with gasket
Old Sep 21, 2022 | 03:19 PM
Rounders's Avatar
Rounders
You could also argue the cam pulled on the inner race. I believe they should be pressed by outer race.
Buy new ones. iMO
badaim
Twin Cam Motors
Feb 6, 2022 04:34 PM
Sandcrab
Oct 1, 2020 11:32 AM
Kaiserboy
May 16, 2018 12:33 AM
Iron lHorse
Dec 18, 2013 09:13 PM
Tltrump
Engine Mechanical Topics
Mar 27, 2012 07:16 PM
