Odometer Not Functioning
Old Sep 29, 2022 | 02:48 PM
Wagondog's Avatar
Wagondog
Default Odometer Not Functioning
Perhaps the forum guys can point me in the right direction. Im ok cranking wrenches but fall short with electrical.
Came home today to find an inoperative odometer on my 2000 carbed Heritage. Everthing else operates except I have no illumination in the odometer window.
Upon further checking I find the odometer is working just not illuminated. Is there a light in the speedometer console that could need replacement.
Thanks for your help where to begin
Old Sep 29, 2022 | 05:52 PM
Vipers Harley's Avatar
Vipers Harley
so everything is working except the light in the odometer window?
Old Sep 29, 2022 | 06:54 PM
hattitude's Avatar
hattitude
If the speedo is working except for the light, I don't believe it is an easy fix...
I went through changing the speedo on my 2001 carbed softail.... as I remember, it is a self-contained, sealed unit.
There is no "bulb/socket" that is an easy customer replacement. I believe the speedo light is integral to the speedo, inside the sealed housing. I suspect it is a bulb on a circuit board....
There are videos showing how to peel back the trim ring and open the speedo. If you have the skills to change/solder a new bulb on a circuit board you can handle the fix.....
Old Sep 29, 2022 | 09:18 PM
Wagondog's Avatar
Wagondog
Correct!
Old Sep 29, 2022 | 09:20 PM
Wagondog's Avatar
Wagondog
If the speedo is working except for the light, I don't believe it is not an easy fix...
Probably a new speedo assembly is in order
Thank you
harlot
2018+ Softail Models
Mar 31, 2021 06:23 AM
El Chiguete
EVO
Jul 5, 2017 05:52 PM
fatboy1729
Sep 3, 2014 08:00 PM
WHOSNEXT
Mar 9, 2009 11:14 PM
Am4wag
Sep 14, 2007 07:05 AM
