question
Old Oct 6, 2022 | 11:48 PM
gerald martin's Avatar
gerald martin
Default question about Frankenstein trike kits
Has anyone converted their 2002 carbureted Harley fatboy to a Frankenstein trike and if so did you have to get it put in trike mode or side car mode to keep it from shutting off when going around corners?
Old Oct 7, 2022 | 07:01 AM
WKNDS's Avatar
WKNDS
Have you checked for any codes ? The older Harleys take some finagling to get the codes to show....
Also, it could be the tip sensor or bank-angle sensor. You might need to by-pass it.
Here's a post about the same issue on a newer Softail trike conversion with the same issue...
https://www.hdforums.com/forum/softa...or-bypass.html
good luck,
T.
Old Oct 8, 2022 | 09:01 AM
hattitude's Avatar
hattitude
I have no trike experience, this info is second hand from reading about side car and trike conversions. If I am in error, I hope someone will certainly point it out...
The later EVO motors ('96+) had a "Vehicle Attitude Sensor" in the nose cone electronics with the cam sensor. I believe that all changed with the Twin Cam...
I believe the BAS (Bank Angle Sensor) is only on EFI bikes with Twin Cam engines. I've read that is the sensor that will shut off the engine if you get really aggressive when driving a trike or sidecar hack.... But from what I've read, it takes a real aggressive move, literally with the side car in the air "flying the chair", or rear wheel up in the air on a trike, to set it off...
I think you are referring to the need to reconfigure 2006+ security systems between the solo setting to the sidecar setting (requiring the installation of the Bank Angle Sensor switch kit) when adding a side car or converting to a trike.
I don't believe you need to worry about it on either an EFI or carb 2002 bike....
I found this post, and saved it a few years ago, when doing side car research. It was on another forum, posted by former Champion sidecar and Lehman trike shop owner:
I hope this helps....
Old Oct 8, 2022 | 03:41 PM
gerald martin
Default question
Thanks for your answers I am going ahead and installing the kit
jtb4ever
Jul 11, 2021 02:03 PM
Katemo
Nov 22, 2018 11:25 AM
Stageman
Apr 4, 2015 02:17 AM
palatium
Exhaust System Topics
Dec 6, 2009 04:06 PM
Casper
Mar 21, 2008 10:44 PM
