Tip sensor Bypass
Old Apr 24, 2021 | 07:21 PM
Mbishoff's Avatar
Mbishoff
2nd Gear
Default Tip sensor Bypass
Did a Frankenstien Trike conversion on a 2014 Fatboy, does anyone know how to bypass or remove the TIP sensor.
Thanks
Mike
Old Apr 24, 2021 | 07:51 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Congratulations on your first post to HDF, welcome to the forum. Have the dealer switch off the function with the Digital Tech.
Old Apr 25, 2021 | 07:14 AM
Mbishoff's Avatar
Mbishoff
2nd Gear
Thanks Coolbreeze
Old Apr 25, 2021 | 07:31 AM
smitty901's Avatar
smitty901
How it is done depends on the year. A good indy with the tech tools can shut many of them off. best route of some trikes is to use the relocate but again depends on the year of the bike.
You do not really shut the BAS off. When it is switched to trike mode or sidecar it tells BCM to look for a different source. If it does not find one it will disable the current one . But depending on year throw a harmless code. .
Many dealers will refuse to make the change for you.
Old May 1, 2021 | 05:09 AM
Mbishoff's Avatar
Mbishoff
2nd Gear
Default Tip sensor
Had to go to dealership could not disable tip sensor but re programmed BCM to look at external sensor.
gtwalker1969
Apr 13, 2018 08:13 AM
markdavidson
2014-2024 Touring Models
Sep 19, 2016 04:29 PM
johnl111
May 5, 2016 08:31 PM
jimmyg61400
Exhaust System Topics
Mar 22, 2012 03:54 PM
brandanfinn
Jun 27, 2007 09:04 PM
