singlefire ignition worthwhile for '98 Fatboy?
Old Aug 19, 2007 | 04:15 AM
JimmyR's Avatar
JimmyR
Default singlefire ignition worthwhile for '98 Fatboy?
This is my first question here - so be gentle guys! I recently got a stock '98 Fatboy with low milage and I'm loving it. I've put some V+H stepped drag pipes on it, a Mikuni HSR42 carby and taken off lotsa stuff. I also replaced the forward controls with some killer stuff from Excel. I'm now wondering if it's worthwhile to try an aftermarket singlefire ignition like a Cranes or something. The Mikuni has certainly given me a LOT more low-end grunt. I'm not so fussed about peak power, I just like to be able to get out of trouble when the light goes green.
Right now I am really liking the extra grunt from the Mikuni and it seems to be tuned pretty good out of the box. I will be getting it onto a Dyno tuner soon to see if I can get any more out of it. But does anyone here have experience with a similar set-up and could recommend an aftermarket ignition system?
Thanks!
Old Aug 19, 2007 | 07:49 AM
smknflms's Avatar
smknflms
Default RE: singlefire ignition worthwhile for '98 Fatboy?
..yep...a dynatek Dyna 2000..http://www.dynaonline.com/english/harley_dyna2000.htm
..allows you to fine tune, run single or dual fire, set rev limit. When I put mine on my 98 softail I got a noticeable performance boost . Really simple install.
Later
Old Aug 19, 2007 | 09:28 AM
JimmyR's Avatar
JimmyR
Hey thanks! I'll check it out. I was pleased with ther difference the Mikuni made, so any more will be a bonus!
Old Aug 20, 2007 | 10:17 AM
Rock4gzus's Avatar
Rock4gzus
Adding the Crane single fire ignition made a noticable difference on the performance of my 98 FXSTC which is also equipped with a Mikuni 42, Big Sucker aircleaner, and Vance & Hines Big Radius exhausts. The Dyna 2000 may be better but I feel that the Crane single fire was money well spent.
Old Aug 21, 2007 | 07:05 AM
JimmyR's Avatar
JimmyR
Yeah I've been looking at the Crane also. Good to hear that both have had a good result for you guys. I really don't want to get into changing cams and all that. I like the idea of those mini Coils that Dyna do - wonder if you could a pair behind the horn??
Thanks!
Jox818
Feb 3, 2016 04:42 PM
deez nuts
Sep 21, 2012 08:06 AM
t150vej
EVO
48
Jul 23, 2012 07:39 PM
03lowrider
EVO
Oct 2, 2011 08:10 AM
SDozier
Apr 24, 2007 08:34 PM
