Automatic Primary Chain Tensioner Issues
Old Dec 8, 2022 | 06:12 PM
JD3's Avatar
JD3
Default Automatic Primary Chain Tensioner Issues
Hi guys,
quick question on primary chain tensioners. I have a new Low rider with an automatic one.. The chain is way too tight and making noise. Is there anyway to take out the tensioner and adjust? Or is my only option to buy a new one and start over?
thanks in advance!
Old Dec 8, 2022 | 06:48 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by JD3
Hi guys,
thanks in advance!
Remove it, reset it then reinstall.
Old Dec 8, 2022 | 07:18 PM
JD3's Avatar
JD3
thank you! Didn’t know if that was possible or not. I’ll try to do that.
Old Dec 8, 2022 | 07:47 PM
Max Headflow
Here are a couple videos.. Doc Harley shows one way to reset the tensioner... What's in fortunate is that he doesn't show how tight it gets when the retainer is removed.
The second vid the guys questions whether his it too tight. It's not.. He seems to have a problem with either the rear belt being too tight or there is something wrong with the clutch hub bearing or inner primary bearing.
Old Dec 8, 2022 | 07:51 PM
FLASH1970's Avatar
FLASH1970
Pretty sure moonshine harley sells an adjuster that.... adjusts based on heat and oil pressure. Sorry if I am wrong or info is useless.
nobody05
Engine Mechanical Topics
Apr 8, 2019 10:15 AM
jpooch00
Dec 21, 2012 08:24 AM
fulldraw00
Jun 22, 2011 06:32 PM
KBFXDLI
Apr 4, 2008 05:01 PM
DaShoveled one
Feb 8, 2008 11:18 AM
