Smart Alarm
Old Dec 15, 2022 | 12:05 PM
Leonard Johnson's Avatar
Leonard Johnson
Stage II
Angry Smart Alarm
I installed a factory Smart Alarm in my 15 ,FXSB. Had H.D. program in the initial pin, marry the two fobs, take my money and send me on my way. Two chirps on, one chirp off. working normal.
Haven't tried to set off alarm intentionally. The issue now is when riding the idiot light is constantly on. When alarm is active, bike on side stand, light pulses normally. After starting the bike the light comes on steady and doesn't turn off ??? Any logical explanation for this would be appreciated.
Old Dec 15, 2022 | 03:57 PM
Bone Doc's Avatar
Bone Doc
The security light will stay on when a diagnostic trouble code (DTC) has been generated. Check for codes and report back what you find.
Here is the procedure for checking for DTCs
Old Dec 16, 2022 | 10:41 PM
Leonard Johnson
Stage II
Sorry for delay. Here are codes thrown b1151;2151;2156;2161, all are BCM I have no power to either brake switches. NO BRAKE LIGHTS ALL OTHER LIGHTS WORK,,,,MARKER,TURN SIGNALS ETC.
Old Dec 17, 2022 | 07:58 AM
CoolBreeze3646's Avatar
CoolBreeze3646
1. Check Fuses
2. Check Bulbs
3. Check wiring harness under fender.
4. Check connections and wiring harness under seat going to the rear lights.
Old Dec 17, 2022 | 08:56 AM
hattitude's Avatar
hattitude
Look up codes here: https://www.fuelmotousa.com/p-29661-...ble-codes.html
b1151 - Bank Angle Sensor (BAS) short to ground
b2151 - Left turn signal output open
b2156 - Right turn signal output open
b2161- Brake lamp output open
As mentioned above make sure to check the connectors under the seat, especially the one to the rear signals... You make have pulled/tweaked something when you installed the alarm.. Also check the connector to the BCM. And by check, I would unplug, inspect pins, add dielectric grease, and carefully reset the plugs.
After checking the connectors, fuses, and wires, then clear the codes and see what comes back...
01flhtc
Jun 22, 2013 07:00 PM
TennesseeMustangPerf
Oct 1, 2011 08:15 PM
THABULL
Jun 30, 2009 08:43 PM
fedfuzz79
Mar 25, 2006 12:07 PM
pipefitter537
May 23, 2005 12:18 AM
