Final Drive Sprocket
Old Dec 17, 2022 | 05:24 PM
FATBOYLO20's Avatar
FATBOYLO20
2nd Gear
Default Final Drive Sprocket
Im a new Harley owner and I bought a 2012 Fatboy Lo. About a month ago the final drive sprocket broke off when the bolts snapped in the wheel, I walked the bike back to my house and when I went to turn the bike on I get a click. Could it be that the bike won’t turn over if the belt is loose or is there something else I have to worry about ?
Old Dec 17, 2022 | 06:00 PM
CoolBreeze3646's Avatar
CoolBreeze3646
COngratulations on your first post to HDF, to the FORUM.
Yep probably time for a new battery - get it load tested first. Has nothing to do with the belt or your drive sprocket bolts shearing off. Plenty of threads on the sprocket bolts, use the search function.
Maintenance is the key, if you do not have a factory service manual, highly recommend getting one if you are going to do your own work.
Be aware you will need to have a full inspection of your wheel and threads in the wheel. If you have not done this before, better to get a professional to look at it. New factory bolts are in order.
Old Dec 18, 2022 | 09:00 AM
Screamin beagle's Avatar
Screamin beagle
Just based on the two bolt holes in that one picture I would say that wheel is now wall art. New wheel, new bolts. As for it not starting...sounds like a coincidence and probably start with testing the battery and checking the connections
Old Dec 18, 2022 | 04:07 PM
IBE's Avatar
IBE
did you walk it back with the key on? i would just replace the battery.
Old Jul 2, 2023 | 01:14 PM
FATBOYLO20's Avatar
FATBOYLO20
2nd Gear
I forgot to update you guys sorry about that, wont happen again. i fixed those issues, i took the rear wheel to Brooklyn Mayd, a shop near my work place, they removed the snapped bolts and mounted a new sprocket. While i had the wheels of i decided to get them painted, wasn’t a fan of the polished silver lip the wheels come with. In regards to the other issue i was having, you guys were correct with diagnosis the battery was shot i swapped it out and the bike started right up. THANK YOU GUYS
. By the way shout out to Brooklyn Mayd they got the job done quick and didnt charge me an arm, if any one in the NYC area needs work give them a call.
TnFatboy
Aug 5, 2021 10:00 AM
Paul32730
Touring Parts
Apr 14, 2021 09:56 PM
delbridge11l
Jun 13, 2017 11:17 AM
SPOILER BAIT
Nov 6, 2015 05:59 AM
toastman
Nov 24, 2012 12:40 PM
