Help! 1989 Springer Softail Stuck
Old Jan 4, 2023 | 01:34 AM
RadRacer's Avatar
RadRacer
Stage I
Default Help! 1989 Springer Softail Stuck
Hi Guys,
I'm at my wits end here and have now narrowed an issue down to a possible stuck or fallen off front piston (I think).
Short story.
Was riding around and saw my left boot covered in oil so cut the trip short. Bike wouldn't start after that. My plan was to start it and narrow down the leak, but the bike just clicked. I went through pretty much everything including installing a new starter. After all that I had myself and one other just try to roll it, but cant get it to turn. It's definitely coming from the front end. Bike didn't lose much oil, but had a good spray coming out on my leg. Regarding the no starting, one friend has suggested the piston head may have come off, but I haven't ventured any further for now. Prefer to throw it out to the forum and hear some thoughts. Hoping it's not seized, but it's beyond my knowledge base now. Thanks. What a nightmare.
Old Jan 4, 2023 | 04:20 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Pull the spark plugs, but the transmission into 5th gear and see if you can push the bike.
Old Jan 4, 2023 | 08:33 AM
uncle kebo's Avatar
uncle kebo
As we say in engineering - look for horses, not zebras. If its past your skill level, bring it to a pro to diagnose. Trying to start it can make it worse and more damage gets done by peoples dopey friends because theyre experts... Dont worry until someone tells you theres a problem.
Old Jan 4, 2023 | 08:40 AM
hattitude's Avatar
hattitude
This would be a quick, easy check to see if something is stuck in the engine... Don't force it.... It should push fairly easily with the plugs removed and being in 5th gear...
Depending on what happens, you can them narrow the diagnosis based on your skill set, or you can get a trailer and take it to a pro...
Old Jan 4, 2023 | 11:32 AM
Bone Doc's Avatar
Bone Doc
Who'da thought, @uncle kebo , we have the exact same saying in medicine when diagnosing something. The most common things happen most commonly so look for horses, not zebras.
Old Jan 4, 2023 | 11:47 AM
uncle kebo's Avatar
uncle kebo
All the joys of using my engineering skills while being a manager in a major NYC hospital.... lol...
Old Jan 4, 2023 | 03:06 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Let's start with what Dan said..
We don't have enough information yet, it could be as much as pressure build up in the primary because he fried his stator and it was coming out the stator plug in the primary getting his foot wet cuz everything got super hot and that's why it only went click click click when he tried to restart it.. There could be many things going on here We need a lot more information..
Old Jan 4, 2023 | 08:00 PM
Kenelz's Avatar
Kenelz
I had that with my Shovehead last summer, it was a blown head gasket right where the oil passage is. Probably not your case, as it was pretty easy to see where ithe oile was coming out at. There are lots of possibilites.
Old Jan 9, 2023 | 12:56 PM
IBE's Avatar
IBE
best thing you can do for yourself now is call someone that KNOWS what they are doing. have them come and pick it up. dont even mess with it if you dont know what you're doing. it could cost you a lot more.
Gwr
Twin Cam Motors
May 28, 2020 03:05 PM
1991softail
Mar 11, 2018 11:36 PM
lowflyby
Oct 6, 2009 01:57 PM
noshow
Feb 27, 2009 06:38 PM
91springer
Mar 18, 2006 07:28 AM
