harley wire for handlebars?
Copper wire, not brass, is used. Stranded (multiple, individual lengths of wire twisted together) wire is generally used in auto (including motorcycle) wiring applications. More flexibility is achieved by stranding many more smaller diameter wires together than a few larger diameter wires. The smaller diameter wires in a flexible strand are easier to break during assembly, however.
Seven-strand wire is often used in industrial wiring applications. Most wire used in automotive applications is 19-strand.
I was just shopping on eBay last night for wires. One listing was specified as GLX. I looked up GLX and it is automotive wire. There is SLX and GLX. SLX has heavier insulation, so a larger outside diameter for same guage wire. GLX has a smaller diameter but the wire is not as flexible. Both are good for engine compartments so I assume they are fine for handlebars. i found one seller that had packs of 16 gauge GLX, 10 colors, 10 feet each. I haven't looked for sheathing yet and I'm not sure if the 7 strands of 16 gauge will fit through the switch housing/ dimple for external wiring. I am working on a 84 FXST, seven wires each side, 16" apes, externally wired. I'm going to need connectors too for under the tank. PO really did a number on the wires when they installed the bars.
The have/had good prices on both types of wire in your post.
