LUGGAGE RACK WEIGHT LIMIT
Old Aug 23, 2007 | 03:01 PM
oldslug66's Avatar
oldslug66
Default LUGGAGE RACK WEIGHT LIMIT
The weight limit on my luggage rack is 10lbs,has anyone ever exceeded this limit without damaging something ?
Old Aug 23, 2007 | 03:08 PM
HD7585's Avatar
HD7585
Default RE: LUGGAGE RACK WEIGHT LIMIT
I have had atleast 25 lbs on the rack on my fxst
Old Aug 23, 2007 | 03:10 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
I didn't try too much with mine before I switched over to the Tribar light. I don't think that plastic tailight housing can handle a lot more than the 10lbs they rate it for. I know they under rate it, but they have too for safety issues and liability. But I doubt it could handle more than 25 to 30 on its own.
WhenI installed theTribar light you have to get an adaptor for the rack and its fairly heavy duty metal and should beable to handle at least 35 to40lbs. without a problem.
Old Aug 23, 2007 | 03:13 PM
oldslug66's Avatar
oldslug66
I forgot to mention ,mine is a FLSTC ,it has the 2 up sport luggage rack which is not supported at the back.
Old Aug 23, 2007 | 03:16 PM
ORIGINAL: oldslug66
OOPS!! Your going to have to be careful with that one. Without support in the back I think I wouldn't go too far over the 10lbs they specify. It will probably handle up to 20lbs OK. But more than that I think is going to be a bit of a gamble.
Old Aug 23, 2007 | 03:21 PM
oldslug66's Avatar
oldslug66
I plan on carrying about 15lb,so maybe it will be ok.I suppose it's a bit like putting sell by dates on food,they have to cover themselves.Thanks everybody for the info
Old Aug 23, 2007 | 03:33 PM
imboden's Avatar
imboden
20lbs on my bobtail rack
Old Aug 23, 2007 | 03:51 PM
oldgeezer's Avatar
oldgeezer
Go way over the 10# limit and have never had any problems.
ORIGINAL: oldslug66
If you tie it down 'right', like to an upright instead of the flat part of the rack, it should be able to handle that much without a problem at all.
Old Aug 23, 2007 | 05:02 PM
kato1964's Avatar
kato1964
I just completed an 8100 km trip about two and half weeks back. (My 3 best weeks this year, by far!! lol) I had a good 25 - 30 lbs of camping gear bungeed on there the entire trip, and had zero issues. I wouldn't start carrying an anvil back there or anything, but I'd say the 10 lb weight limit is quite conservative. The 15 lbs you mention should be no problem.
