Fxst softail 2002 engine noise
Old Jul 9, 2023 | 10:18 AM
Max K's Avatar
Max K
1st Gear
Default Fxst softail 2002 engine noise
Hi guys, Anybody knows why my Softail is making this squeeky sound at startup and at revving?
File Type: mp4
Old Jul 10, 2023 | 08:30 AM
hattitude's Avatar
hattitude
Has it always made that sound, or did it just start doing it...?
Did you do any work or repairs recently...?
I don't recognize that sound from my experience, but it could have several causes. Your video shows the comp portion of your primary... is this where you believe the sound is coming from?
Old Jul 10, 2023 | 08:50 AM
Max K's Avatar
Max K
1st Gear
I made some changes a couple of months ago. I removed stock air filter and pipes and put in new ones. Vance and Hynes pipes and an open air filter.
The sound started about a week ago. I strongly believe the sound comes from my primary.
The sound goes away when the engine is hot and i can't feel any changes in performance. The bike runs good.
Old Jul 10, 2023 | 07:04 PM
hattitude's Avatar
hattitude
If you are pretty sure it's coming form the primary, and no where else like a loose part on your new exhaust or air cleaner, pull the primary cover and check things out...
It'll only cost you a quart of primary fluid...
You can check the primary chain tension and look around to see if everything looks to be working properly...
Old Jul 11, 2023 | 05:50 AM
Max K's Avatar
Max K
1st Gear
Ok! I will open up the primary and check on it.
Now i can only hear that noise at ignition. When i put the bike in gear, it stops, and once i get on the road and drive it, the noise is gone.
Old Jul 11, 2023 | 06:43 AM
RANGER73's Avatar
RANGER73
If it goes away when you put it in gear it might be a loose tensioner in the primary causing your chain to slap.
Stevecg89
Mar 24, 2018 09:52 AM
macca
Oct 2, 2014 12:07 AM
harley4348
Apr 15, 2007 08:47 AM
