Which bolt size?
Old Aug 7, 2023 | 05:29 PM
04FXDI's Avatar
04FXDI
Originally Posted by Alok
I do plan to keep the bag as-is as I routinely bike to work and that holds my office bag, helmet, gear etc. I don't think I will use the side bags ever so for now will close the open spaces with the default bolt. For the longer bolts might check if I can get a couple more of those and just trim off the ends or else buy some new ones in size with a hex head or so. Love yours clean look!
Thanks, give me some, maybe a day. I'm pretty sure I have all that hardware somewhere; I can get you sizes. I did swap everything to Allen Heads as well. IDK if you have a passenger or not but they make a rack for that Tour Pack that turns it into a Solo, works well as a backrest.
Solo Pack Luggage Rack Mount Fit For Harley Tour Pak Softail FLSTSC Fat Boy FLST | eBay
Old Aug 8, 2023 | 05:04 AM
04FXDI's Avatar
04FXDI
So, I dug through some of my Hardware bags. Looking at your pictures, starting from left to right.
The Front Saddlebag stud that's also used for the Quick Release Bushing should be. 3/8-16 x 1.75" at 2 each.
I also used a conical washer as a dress up for all of them.
The hole in the middle is indeed the #3 bolt shown in the kit. 3/8-16 x 7/8" a 2 each.
The last hole on the far right is same as the front one. 3/8-16 x 1.75" at 2 each.
With this hardware you should be able to eliminate the long saddlebag studs, and keep your quick release
bushings, so that you can run your Tour Pack. Hope this helps.
Lee F.
2018+ Softail Models
Jan 14, 2021 09:55 AM
Hogpro
Apr 2, 2016 04:09 PM
scrapez
Feb 9, 2015 03:09 PM
boomer9090
Feb 28, 2008 04:21 PM
1200cc
Jan 16, 2007 11:41 AM
