wont start
Old Aug 14, 2023 | 08:40 PM
  #31
H.B's Avatar
H.B
Originally Posted by Jackie Paper
Too cool Hyden.
See the CPS go occasionally. When you took it out, did it have any buildup on it.
didn,t see any, the plug end has a lot of oil and build up on it but the inside was clean. Didn’t see any oil leaks. I bought the bike used, just figured they were nasty with oil changes.
Old Aug 14, 2023 | 08:42 PM
  #32
H.B's Avatar
H.B
How can you check a crank sensor
Old Aug 14, 2023 | 11:55 PM
  #33
Tom H's Avatar
Tom H
There is an electrical test with a volt meter for them. The service or electrical manual should have the specs. But one that tests fine, may not work,
Or put the suspect one in the bike you pulled the working one out of and see what happens. If it won't run, the sensor might just be bad.
Tom
Old Aug 15, 2023 | 05:53 AM
  #34
Jackie Paper's Avatar
Jackie Paper
There difficult. That electric is coming to ECM. The notches on the crank wheels as they spin by generate it. Just a little green corrosion on a wire attachment to a pin would kill it. Once that happens, unplug and replug may fix it only temporary.
It's not going to show any resistance on your average garage tools. Needs a scanner while cranking or running. Only the latest Harley finally went to latest OB system but still require a adapter to hook it up. They fight us to the very end to discourage us
I have a 46 Chevy Truck. It has 3 size dogbone fasteners on it. Old owners manual suggest to always take in in for service.
When you crank a Harley, the ECM needs so many hits and then that bigger missing notch on the crank wheel. Only then will it start to fire
(PS. Think Hall Effect on how it functions)
Google it and refresh my 75 year old processor. My minor in electronics was when I had a TV with tubes (really )
Old Aug 15, 2023 | 09:48 AM
  #35
H.B's Avatar
H.B
Tom
don’t take 5 min will put the suspect one in other bike see what it does. Will let you know!!
Old Aug 15, 2023 | 09:19 PM
  #36
H.B's Avatar
H.B
Tom
I put the BAD one in the other bike and it won’t hit a lick. So it is just bad!! The new one will be here tomorrow, will get that one going.
Old Aug 15, 2023 | 09:24 PM
  #37
Tom H's Avatar
Tom H
At least your sure it's bad. Good work!!
Tom
Old Aug 15, 2023 | 09:47 PM
  #38
H.B's Avatar
H.B
Again, I want to thank you guys for getting me in the right direction
Old Aug 16, 2023 | 09:29 AM
  #39
H.B's Avatar
H.B
Got the new crank sensor today, not home to try it but think the wiring is too short. No way the clip will reach the back of regulator plate, where it snaps on.
Old Aug 16, 2023 | 11:26 AM
  #40
hattitude's Avatar
hattitude
Some models/years have different length wires...
IIRC, you have an '03 Softail. That should be part #32707-01C......
