2002 harley fat boy
Old Nov 2, 2023 | 04:04 PM
gerald martin's Avatar
gerald martin
Default 2002 harley fat boy
Can anyone tell me what rpms am I running at 50 mph on my 2002 Harley fat boy
Thanks in advance
Old Nov 3, 2023 | 08:43 AM
Longobard's Avatar
Longobard
All depends on your gearing and what gear you are in at 50MPH. The Gearing Commander calculator was useful when I was searching for a similar answer for me.
Gearing Commander
www.gearingcommander.com
Old Nov 8, 2023 | 12:29 PM
byersmtrco's Avatar
byersmtrco
Thanks in advance
Hopefully, you're not in 5th at 50 mph. Chug-a-LUG !!!
Old Nov 8, 2023 | 08:18 PM
gerald martin
What do you mean by your comment? do you not think 50 mph is the right speed or what?
Old Nov 9, 2023 | 06:43 AM
eighteight's Avatar
eighteight
Baker calculator shows 2117 rpm in 5th @ 50mph
Old Nov 9, 2023 | 06:03 PM
byersmtrco's Avatar
byersmtrco
At 50, you should be in 4th. As the above post states, your only around 2100 rpm. Running that slow in 5th is hard on the engine,
especially under a load (hills etc)
Minimum rpm should be 2500
I don't shift into 5th til I'm doing 55 or 60
Old Nov 9, 2023 | 06:57 PM
gerald martin
Default 2002 Harley fat boy
Thank You.
I will will wait until I hit 55mor 60 mph. The speed limit in British Columbia is mostly 55 mph or 90 km so I guess I will be OK
Old Nov 10, 2023 | 08:52 AM
tmac00333's Avatar
tmac00333
Actually, HD says to shift into fifth at 45 mph, if I recall correctly. I never do. I usually hit fifth at 55 or 60.
Old Nov 10, 2023 | 05:01 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Lugging is load and rpm sensitive.
You can putter downhill at idle in 5th gear without any problems. You can't go back up the hill that way.
There isn't one single magical rpm for all conditions.
mine112233
Electrical/Lighting/Alarm
Apr 20, 2022 05:34 AM
gduncan
Motorcycles For Sale
Mar 16, 2021 07:06 PM
monyman
Harley Davidson Videos
Jan 25, 2008 08:34 PM
