TC 96 vs 103
Thanks
Lucky Pete
There were several versions and updates to that compensator. Finally in 2014 with Rushmore bikes, they came up with a version that has been far less problematic than its predecessors.
If your bike model didn't come with it, you can add it as a retrofit kit. It is the current Screamin' Eagle Big Twin Compensator for about $400. There are a couple different part numbers/retro fit kits, depending on the fitment.
Both the 96 and 103 are good engines. Many different years/models had quirks, but there are really no problems that don't have solutions.
While shopping, if you suspect a comp problem, I would deduct $$ from the asking price to be able to get the latest comp kit. If all else on the bike and with the deal looks really good, a noisy comp would not scare me away from the purchase, ...
Good luck with your bike shopping.... it can be part of the fun..!
I'll admit I have trouble keeping all the subtle differences straight in my head, so forgive me if I am remembering this wrong....
The difference between the Twin Cam 96" and the Twin Cam 103" are the cylinders and the pistons.... the bottom ends (crank/stroke), heads, and drivetrains are the same...
If my memory is failing me, I will be corrected shortly...
