Flasher relay
FWIW.... the pre-Canbus bikes, like your 2009, will hyper-flash when adding LED lights. They need a load equalizer to stop the hyper-flash. I've never heard of adding a "flasher relay" to fix that problem. I guess it could be different on the international models, but this would be the first time I heard of that difference.
You may want to check the part number of the Badlands Illuminator run/turn/brake module you purchased. They have a couple different types of that module.
I suspect your Badlands Illuminator is their stand alone run/turn/brake module, instead of their combination run/turn/brake module with built-in load equalizer like the one below..
https://www.revzilla.com/motorcycle/...sku_id=1799035
If you did get the one with the built-in load equalizer, I would suspect something is amiss with the installation or the module may be faulty...
Keep us posted on what you find...
