PTFE thread sealant for drain plug?
Old Apr 13, 2024 | 12:26 PM
slonez_sg's Avatar
slonez_sg
Default PTFE thread sealant for drain plug?
My engine oil drain plug has a slow leak.
Tried new drain plug, new o-ring. Leak still present.
I know that it is not recommended to use PTFE tape.
Would a thread sealant like this be ok for use on oil drain plug?
https://www.grainger.com/product/HER...al-Tuff-20CM12
I happen to have this in my office.
Old Apr 14, 2024 | 01:29 AM
Hawg Runner's Avatar
Hawg Runner
I would think it would be okay as long as you don't get sloppy with it.
Old Apr 14, 2024 | 07:37 AM
benscratchin's Avatar
benscratchin
I don't think it will hurt to use it. A better place for this question would have been over in the "Tech and Mechanical" forum.
This is basically the same product and can be found at your local auto parts store, for less money. Permatex 59214 Permatex High-Temperature Thread Sealant | Summit Racing
Keep in mind that some residual oil remains in the bottom of the case while the bike is resting in the jiffy stand, Secure the bike upright if possible, to drain the oil. If time allows let the oil drain overnight. I like to clean the oil drain hole threads with alcohol (or degreaser) and a paper towel prior to reinstalling the plug.
Old Apr 14, 2024 | 07:59 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What drain plug?
Old Apr 14, 2024 | 08:22 AM
hattitude's Avatar
hattitude
It is unusual for an oil drain plug, the type with a shoulder and o-ring, to leak. Are you SURE the leak is from the oil drain plug, and not just migrating to, and dripping off the oil drain plug from somewhere else...??
If the Standard HD oil drain plug w/o-ring is leaking, it is usually an issue with either the o-ring (wrong size) or the machined face the o-ring seats against (like a bur). Sometimes, if you don't put a little oil on the o-ring, during install it may "catch" and get twisted or torn, especially if there is a bur on the mating service.
A properly installed O-ring drain plug, with the proper size o-ring, should not leak...
Having said that, Harley used to have a pipe plug style primary drain plug.
They are not tightened to a torque value, but are given a depth value. The service manual stipulates how much it should protrude from the bottom of primary case. I have two early twin cams with those pipe plugs in their primaries, and I always use a thread sealant on those.
I use Loctite 545 thread sealant on those primary plugs.
Would it hurt to use the 545 Sealant on an o-ring style drain plug.....?
No, but it would bug me why the proper plug isn't doing it's job....
Old Apr 16, 2024 | 08:23 AM
slonez_sg's Avatar
slonez_sg
I have applied the paste on the drain plug.
I'll check again tomorrow to see if it works.
Old Apr 16, 2024 | 10:18 AM
Dan89FLSTC's Avatar
Dan89FLSTC
What drain plug???????
Old Apr 16, 2024 | 10:30 AM
jake24lt's Avatar
jake24lt
Or Joey Overtorque tighened the snot out of 'The Plug" and possibly cracked the pan/primary case, or wherever said plug is!
Old Apr 16, 2024 | 10:39 AM
CoolBreeze3646's Avatar
CoolBreeze3646
What drain plug?
I would say it is the engine oil drain plug
I would again say it is the drain plug that drains the engine oil and not the primary or transmission oil plugs
^^^ I would investigate this as putting Teflon tape or PTFE sealant is just a band aid to the real problem. Would remove the plug (the one for the engine oil) clean around it the area good with brake cleaner then get my phone under there and take a few pictures to see if there are any cracks.
What year and model bike???
Old Apr 16, 2024 | 10:52 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Did the plug go in sideways and the o-ring doesn't sit correctly?
