Help with oil leak
Define puddles....?
My idea of a puddle is a lot of oil to leak from anywhere...
Externally vented breathers can definitely leave spots on the floor.
OEM vented breathers can take awhile to saturate the lower section of the air cleaner, but once it starts to drip, can definitely mark their territory..
A oil leak that leaves "puddles" needs to be found and dealt with... Usually, if it leaks a "puddle" it doesn't just stop...
I would clean up the engine really well with a degreaser. Then go for a ride or two until you see a puddle under the bike.
Then get down on the floor and follow the trail of oil from the puddle, to the engine/primary/transmission, and up to its source....
