Tri Bar install
Old Aug 30, 2007 | 09:53 AM
crock921's Avatar
crock921
Default Tri Bar install
my question, since I am picking up my bike tomorrow, is this...are the screw/bolts holding the FXSTB tail light on torx, standard, or what? The dealer said he had not looked at it very closely but thought it may be torx. even after $4,000 in parts and labor, they do not want to install it for me at no charge which chaps my @ss, but what are you gonna do I guess.
Old Aug 30, 2007 | 10:00 AM
IsurvivedNMU's Avatar
IsurvivedNMU
Default RE: Tri Bar install
It takes about 20 minutes to install.... I think the light cover is held on by 2 phillips heads, and the case is on by (4) 9/16 bolts.
The tri bar license plate braket uses allen wrenches...
Old Aug 30, 2007 | 10:03 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Sorry, I missread the question. The light lens itself is held on with a pair of phillips screws. Not sure now if you have to take the fender support rails off just to put the tailight in, I did for the rack adaptor, but if you do the fender support rails useTorx T-45 bolts, an they use locktite on them so they can be tough to get out. Use a good set of bits that fit properly or you WILLmess them up, and regret it later.
Old Aug 30, 2007 | 10:04 AM
crock921's Avatar
crock921
okay good, I wont even worry aboutit then. I will just do it when I get home. I was concerned because I do not have any torx drivers, but it is good to hear that I have no worries. thanks.
IsurvivedNMU
ORIGINAL: Citoriplus
Yes the bolts on the fender support rails areTorx, T-45 to be exact.
I just did this on my nightrain last weekend. There were no torxs bolts....
Old Aug 30, 2007 | 10:07 AM
crock921's Avatar
crock921
uh oh. HD is mixing up the bolts!
Old Aug 30, 2007 | 10:15 AM
ORIGINAL: IsurvivedNMU
Sorry about that, I fixed it.
Old Aug 30, 2007 | 10:33 AM
crock921's Avatar
crock921
sounds like I should pick up a t-45 anyway since it is needed for the bike. I also will be installing the detachable sissy bar hardware, so that may require the torx bits that you are referring to.
Old Aug 30, 2007 | 10:55 AM
If your going to do that get a good set of them, just make sure it has a T-27 in it. For some reason its not commonly included in many of the sets but Harley does use it on there bikes.
Old Aug 30, 2007 | 11:35 AM
crock921's Avatar
crock921
i always buy craftsman. I have had nothing but good luck with their products and they have a lifetime warranty.
