2002 Fatboy turn signals not working
Old Jul 11, 2024 | 02:59 PM
CDSomerlock's Avatar
CDSomerlock
2nd Gear
Default 2002 Fatboy turn signals not working
Hi all. I'm hoping somebody can help because I'm at a loss. I have no turn signals. I have changed the circuit board in the tail light, one of the connectors from one of the turn signals, the harness going under the fender, The turn signal module (eBay), the fuse, both handlebar switches, and I still have no turn signals. I put a Badlands TSM on and I get front left turn signal but the other still don't work. I'm ready to torch this thing.
Old Jul 11, 2024 | 03:17 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Have you checked all fuses?
Exactly what happens when you turn the left turn signal on?
What happens when you turn the right turn signal on?
Did you cut, splice or modify the original wiring?
Old Jul 11, 2024 | 03:57 PM
CDSomerlock
2nd Gear
Yes I checked all the fuses. There's not a single splice in the harness. When I push the left turn signal button I get the front left turn signal but not the rear. And only if I add a aftermarket flasher plugged in between the main harness and the harness that runs under the fender. Nothing happens when I hit the right turn signal. And nothing happens when I push both turn signals. It's possible I bought a bad TSM but both of them are acting the same...
Old Jul 11, 2024 | 05:23 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Leave any aftermarket stuff off for now, so you can troubleshoot the wiring to make sure the circuits are intact.
First, let`s make sure the TSM is getting the signal from the turn signal switches on the handlebar:
Unplug the TSM.
At the TSM connector on the harness, read the voltage at the White/Violet wire in the connector when you press the left turn signal button (ignition on).
What is the voltage reading?
Old Jul 13, 2024 | 01:32 PM
CDSomerlock
2nd Gear
Unplug the TSM.
TSM removed and...
White/violate = 12.3v while holding left turn button.
White/black, next wire, 12.3 while holding right button
Old Jul 17, 2024 | 02:36 PM
CDSomerlock
2nd Gear
Default 12v
Unplug the TSM.
I have 12 volts at the turn signal input at the TSM plug when you push the appropriate turn signal button. So whatever the problem is, it's not the input circuit.
Old Jul 21, 2024 | 07:03 PM
panhead_pete's Avatar
panhead_pete
Have you checked the bulbs?
eviltwin69
Jan 13, 2024 06:03 PM
Sbrewer31571
Oct 5, 2017 07:56 PM
Rogue8Man
Electrical/Lighting/Alarm
Aug 16, 2015 03:45 PM
ws6lvr
Mar 22, 2013 03:04 PM
gotnobrakes
Aug 2, 2007 05:53 PM
