Turn signals not flashing
Old Oct 1, 2017 | 12:07 PM
Sbrewer31571's Avatar
Sbrewer31571
Stage II
Default Turn signals not flashing
I have a 2000 fat boy it didn't come with turn signals on from the factory but has everything to install them I bought led turn signals and installed them along with the load equalizers they will light up but won't flash could it be the turn signal module?
Old Oct 1, 2017 | 12:44 PM
larsfum's Avatar
larsfum
That bike did come with turn signals from the factory. Someone removed them. Recheck all of your wiring. It may be because of the LED's. What brand of LED's did you go with? Which equalizer? There is a complete flowchart for trobleshooting turn signals in the SM for my 98 RG, but I don't think it would help you.
You said that it came with "everything" to install turn signals. Where did you get the power, and signal for the front and rear lamps? Are you sure that you tapped into the signal power, and not the running light? Also
Old Oct 1, 2017 | 06:54 PM
1340hog's Avatar
1340hog
Also check the flasher
Old Oct 1, 2017 | 11:28 PM
Veekness's Avatar
Veekness
OPW. Again.
Old Oct 5, 2017 | 07:16 PM
Sbrewer31571
Stage II
Ok I still haven't figured it out yet but for some reason the emergency flashers work but the turn signals don't anybody heard of this
Old Oct 5, 2017 | 07:56 PM
giacomo56's Avatar
giacomo56
I just went through the same thing...LED are polarity specific.....switch the the wires going to the LEDs....bet you they will work
rgilkerson
Electrical/Lighting/Alarm
Mar 22, 2020 09:13 PM
Train83
Sep 12, 2017 11:18 AM
ws6lvr
Mar 22, 2013 03:04 PM
Sledge
Nov 10, 2012 01:34 PM
SKJOLD
Apr 8, 2005 02:22 PM
