2022 fxbbs clutch getting loose when hot.
Old Dec 2, 2024 | 11:59 AM
Jetracer1's Avatar
Jetracer1
Stage I
Default 2022 fxbbs clutch getting loose when hot.
Hello, new to riding. I bought a 2022 Street bob as my first bike. It has about 1500 miles on it now. The issue is when I am riding and the bike gets hot, the clutch lever loosens dramatically. When cold, it's nice and tight though. I've tightened the cable through the spring on the side of the forks but afraid to tighten the set screw inside the case due to how tight it is when cold. When hot, the lever gets so loose that it sits on my knuckles and I'm using my fingers to push it back out. The bike isn't under warranty because I bought it used with 60 miles on it. This only became an issue when the bike got to about 900 miles. Any help would be appreciated.
Old Dec 2, 2024 | 05:41 PM
xwhyz1959's Avatar
xwhyz1959
You just need to try adjusting your clutch properly it sounds like to me. It's really easy to do, and you need to acquaint yourself with your bike anyhow. Don't start paying big bucks to the shops for BS work. YouTube will be your friend, it's full of information. Welcome to the Forum BTW, and ride safe my friend.
Old Dec 2, 2024 | 08:31 PM
Max Headflow's Avatar
Max Headflow
Sounds like a girl I used to know..
Old Dec 3, 2024 | 09:09 AM
cobra23's Avatar
cobra23
If you are having trouble with clutch adjustment, I recommend the Fat Baggers metal adjuster that replaces the cheap stock Harley plastic adjuster.
https://www.fxrdivision.com/handleba...er-m8-softails
Old Dec 3, 2024 | 03:26 PM
YZR's Avatar
YZR
SFXDB415
Aug 8, 2017 10:41 AM
rufasim
Apr 13, 2013 12:49 PM
nightie
Aug 24, 2012 09:51 AM
TheDon81
Jul 19, 2012 04:51 PM
dougbk
Jul 1, 2011 06:49 AM
