Larger belt guard recommendations
Old Feb 25, 2025 | 06:56 PM
MileHighGuy's Avatar
MileHighGuy
1st Gear
Default Larger belt guard recommendations
Hello. I have a 2006 Night Train. Just put on new wheels and added a chrome rear pulley. Unfortunately, my stock upper belt guard no longer fits properly (the new pulley is slightly wider than stock). Would appreciate any recommendations for a slightly wider guard. Preference is black, but chrome is fine if I need to go that way. And, yes, I prefer to have a guard in place as I often have another rider.
Thanks in advance!
Old Feb 25, 2025 | 07:08 PM
im's Avatar
im
If problem is "wider" then is using a washer or two to push guard out an option?
Old Feb 26, 2025 | 01:06 PM
MileHighGuy
1st Gear
Started thinking about that last night. Thanks form the suggestion!
Old Mar 7, 2025 | 11:31 AM
MileHighGuy
1st Gear
Upon closer inspection, the end of the lower belt guard was actually slightly bent inboard to the point where it was rubbing against the rear pulley. I heated the guard with a heat gun and reshaped it so now the end of the guard is slightly bent away from the new pulley. I also painted the guard with black wrinkle paint to match the upper guard. Looks better than before now.
Old Mar 7, 2025 | 03:11 PM
hattitude's Avatar
hattitude
Share a pic.....
Marsikus
Aug 30, 2022 03:04 AM
worked4it
Jun 21, 2014 12:41 PM
barrygreen
Oct 30, 2011 03:00 PM
Mr Wasabi
Aug 30, 2008 07:45 PM
pauletich
Jun 19, 2006 10:46 PM
