Fuel line question
Old Jun 9, 2025 | 08:01 PM
tskm143's Avatar
tskm143
Stage I
Default Fuel line question
2006 Heritage Softail,
there is a 3/8-1/2” what looks like a fuel line,
that connects, underneath the tank from one side of the tank to the opposite side(it is fastened via crimped clamps) this line also runs under the frame, without disconnecting, it prevents me from removing the tank. I need to know if this is indeed a fuel line before I disconnect it to remove the tank.
any insight will be greatly appreciated and hopefully prevent me making a total mess.
Old Jun 9, 2025 | 08:35 PM
djl's Avatar
djl
It is a fuel line. You need to drain the tank to avoid a mess.
Old Jun 9, 2025 | 08:38 PM
702's Avatar
702
It's just not a big deal, put a vacuum cap on the tank nipple when you remove the hose and a golf tee in the hose then you can easily remove the tank.
Old Jun 10, 2025 | 06:37 AM
RANGER73's Avatar
RANGER73
Used on split tanks too,
drain the tank(s) and add a quick disconnect for future.
Old Jun 10, 2025 | 06:54 AM
Bass Player's Avatar
Bass Player
If you are going to work on your own bike, an FSM would be your friend.
cptseawolf
Feb 26, 2017 03:49 PM
High Roller
Mar 14, 2015 07:07 PM
baldeagle503
Mar 14, 2014 09:34 PM
Gman in NC
Sep 5, 2011 01:02 PM
rustyed
Jan 6, 2007 12:43 PM
